How to create circular surface
How do you create a surface of circular shape? I know it sounds very simple but I tried drawing a circle and then do it with planar surface button but it didnt work. That button creates only rectanbular surface.. Or I tried revolving a line around z axis, it didnt work. I tried extruding a circle to cylinder and to may be extract a circular surface out of it, but i cannot do it.
How can I create a surface of circular shape in simplest way?
And if I wanted to obtain it from the cylinder solid how to do it?
imadHabash
draw a 2d circle then use PLANESURF command . now select object to create surface .
Command: PLANESURF
Specify first corner or [Object] <Object>:
Select objects:
Imad Habash
vinodkl
Hi @Anonymous
You can create a circular surface using the PLANESURF command. Draw a circle and then use this command to create a circular surface.
The rectangle that you are talking about on the surface is isoline. You can eliminate them by selecting the surface and open the properties palette(ctrl+1) and make the U & V isolines to "0" 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
thanks, i wasnt taking about isolines, i was saying the surface becoes rectangular i guess i needed sto select the objectnot points
