AutoCAD Forum
How to create a pond using the Loft command...
2 REPLIES 2
PH
259 Views, 2 Replies
I am trying to create a pond using the loft command but it is not working as expected is there another way to do this? Please see the attached 3D .dwg with the Pond outlined at the rear of the property but I cannot create the pond from it using the loft command. Please, please help?
Tags (1)
2 REPLIES 2
fatal.error
in reply to: PH
Have you tried setting Ruled at Loft Settings Dialog box?
PH
in reply to: PH
No I did not try this the dialog box does not appear in my version of AutoCAD I tried Rulesurf but that does not seem to be the same command. I will look into this and thanks for your help I am sure if you can do it I can too so I marked your response as the solution!!! Thanks again for your reply to my question.
Forma Design Contest
