Hi everybody!
Somebody knows if it's possible to achieve this kind of pattern?
I think is like this but cleanig the instersections
Thank you in advance!
Gustavo Ubriaco Contreras
Gelöst! Gehe zur Lösung
Gelöst von illusionistNUGXG. Gehe zur Lösung
Not really. Patterns can't contain circles, arcs ellipses etc...
They can only use endless lines or interrupted lines with customized lengths and gaps (and dots) - endless repeated.
You can string multiple lines and gaps together to draw a "morse code" until it starts all over.
The only way i think it could work - not recommended - is:
Create a pattern with circles made out of lines with really huge gaps, that you will never see the repetitions.
That's a lot of work...and the pattern will end, where you stopped creating the circles.
You also have to set the origin point every time you use this pattern. It would be also terribe to use, because of big void areas around the last circle.
Hi!
Thanks for the explanation, I agree with you, actually preffer to make multi offset and then extrim the outsided circle parts.
Would be a great tool like arrar but with concentrical arcs circles elipses
