How to create a field in an attribute inside a block with autmatic caluclation
yu85.info
yu85.info
Hi, I have a block with two attributes - "A" & "B". I want to create another one - "C". I want the value of "C" to be - "A-B"
(A minus B). I want to insert menually the values of "A" and "B" and get the result automaticly in "C".
Can you help me please. I could not find an anwer in the web.
Thank you very much
0 Me gusta
Responder
Soluciones aceptadas (1)
413 Vistas
2 Respuestas
Respuestas (2)
pendean
Community Legend
Community Legend
Most likely non-exist but... post a DWG file, point to A and B in the file so we can see what you are trying to do exactly.
0 Me gusta
JTBWorld
Solución aceptada
Add a field in C and use Object, select the block and the the A attribute. Copy the field expression that might look like this:
%<\AcObjProp Object(%<\_ObjId 2002115822928>%).TextString>%
Then do the same for the B attribute.
%<\AcObjProp Object(%<\_ObjId 2002115822912>%).TextString>%
Finally select Formula and paste it like this with - between:
%<\AcObjProp Object(%<\_ObjId 2002115822912>%).TextString>%-%<\AcObjProp Object(%<\_ObjId 2002115822928>%).TextString>%
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
0 Me gusta
