How to convert this 3d surface to 3d solid?
No aplicable
Hi, I'm trying to convert this 3d surface to a 3d solid. I tried using the THICKEN command but there ended up being too many interferences. Any other methods that might work?
0 Me gusta
Responder
Soluciones aceptadas (1)
508 Vistas
2 Respuestas
Respuestas (2)
john.vellek
Solución aceptada
Hi @Anonymous,
I took your drawing and dropped it into Fusion 360. From there, I printed to 3d to create a STL file.  I then inserted the STL file back into Fusion 360 and i am trying to export to an IGS, STP or ACIS file so I can get it back into AutoCAD.  This is fighting me a bit but I will check with one of my Fusion 360 Specialists in the morning to see if I can get this to work.
I have attached the STL file for you if you want to play with it.
John Vellek
No aplicable
Thanks so much John! I wasn't able to get it to work on my end but that STL of yours opened up just fine in my CAM software so I'm a happy camper right now, thanks!
I'll post a picture of this thing carved out when I'm done!
