how to convert .RCS scan file into a cad solid object
Message 1 of 39
I'm currently using CADWORX plant professional we received RCS scans of our refinery and I'm attempting to pipe the scan with intelligent piping components and I'm having a difficult time seeing the pipes and placing them in the right XYZ. I know there is a way to take the scan and turn it into a cad file with autocad shapes I just don't know what that program is. any and all help is very welcomed
Replies (38)
Message 2 of 39
Alfred.NESWADBA
welcome @Anonymous!
As pipes are in mist cases geometric cylinders I would start with command _PEXTRACTCENTERLINE (>>>details<<<) and when you have the centerlines you can first connect the missing distances and then create pipes along the centerlines.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 39
cadworx isn't recognizing that command. I'm having trouble still
Message 4 of 39
Alfred.NESWADBA
It's an AutoCAD command (as we are here in the forum about AutoCAD 😉
- alfred -
Alfred NESWADBA
Message 5 of 39
so pcextractcenterline works but its not picking up anything from the scan at all.
Message 6 of 39
Alfred.NESWADBA
Are in the pointcloud cylinder-like objects?
When you start the command and (without any object snap) move your cursor "into" such a point-cloud-cylinder ... doesn't the command then highlight the cylinder?
To the pointcloud: are there many scans (rcp pointing to multiple rcs) or just a single scan (rcs) referenced in the drawing?
When you select the point-cloud ... what does the property window show as object type (if not opened please start the property window using <CTRL><1>).
- alfred -
Alfred NESWADBA
Message 7 of 39
so it say point cloud on the properties. and but extract centerline isn't working I want to pipe all the piping with intelligent cadworx components and I am having  very hard time
Message 8 of 39
Alfred.NESWADBA
From my previous post:
Any chance I can download the RCS file to try it by myself?
Please find attached a small video with the steps I do to create the centerlines, maybe that can help ..
- alfred -
Alfred NESWADBA
Message 9 of 39
this is a RCS inserted into the dwg. I'm using what Anvil gave us
Message 10 of 39
Alfred.NESWADBA
Sorry that I don't know who or what "Anvil" is.
Have you seen my video in my previous post? Can you create a video that shows how these steps are working on your workstation (>>>free Autodesk Screencast<<<).
- alfred -
Alfred NESWADBA
Message 11 of 39
I watch the video and followed along and my AutoCAD wont allow me to do that. I'm wondering if its because he point cloud is RCS and not RCP file
Message 12 of 39
Alfred.NESWADBA
Where exactly starts the difference between your AutoCAD behavior and my video.
No, that function works well for both types of attachments.
- alfred -
Alfred NESWADBA
Message 13 of 39
well I pick the centerline button and the program doesn't see the centerline seems like. I did all the same things and I get nothing.
Message 14 of 39
ive tried to attach the scan maybe I'm doing something wrong. but I cant attach the file I think its too big
Message 15 of 39
Alfred.NESWADBA
The function _PEXTRACTCENTERLINE should detect points building up a cylindrical form ... the function does not "see the centerlines", it creates centerlines.
Have you seen that I used a layer with a very light color and with a big lineweight and that I made the pointcloud transparent to see the centerline when it was created?
Otherwise you might not see the resulting polyline as it is inside the pointcloud-cylinder 😉
Upload it to a cloud storage like DropBox, WeTransfer or something similar and show me the link to the data.
The limit here for uploads are abut 70MB.
- alfred -
Alfred NESWADBA
Message 16 of 39
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Alfred is a saint when it comes to trouble shooting.  Please provide your point cloud and drawing file so that either myself or Alfred can show you how we might proceed.
In the mean time, here is another video that might help with creating geometry from the points in your point cloud.
John Vellek
Message 17 of 39
so I have a question about the file type, does it make a diff of file type to make it wor? I have RCS scan files does it need to be PCG scans?
Message 18 of 39
john.vellek
Hi @Anonymous,
Here is an article that describes the different formats. In my opinion, the RCS files should work just fine.
John Vellek
Message 19 of 39
John Vellek,
thank you the video was helpful but I cant seem to get this RCS file to extract centerlines of the piping and tanks that were scanned.....
Message 20 of 39
john.vellek
Hi @Anonymous,
Can you share your files so I can get a better idea of what you are seeing? You can place the data on A360 or another cloud service
John Vellek
