How to convert DWF to DGN
sjlee
sjlee
I would like to know any way to convert DWF to DGN with Autodesk product. (without 3rd party)
I thought that i could convert DWF to DWG and then convert the DWG to DGN, but it is not good way to convert.
Even I couln't know how to load DWF file in AutoCAD...
Is there anybody can help me?
0 Me gusta
Responder
Soluciones aceptadas (1)
4.324 Vistas
6 Respuestas
Respuestas (6)
Alfred.NESWADBA
DWF something like a one way road, you can write it and that this is similar to a "read-only" file to be displayed and printed, but not to be modified any more.
You can use command _DWFATTACH (>>>click<<<) to display the DWF file in your current drawing, but there is no way to convert the DWF back to valid geometry like AutoCAD blocks or so.
What you should do is to ask for the source file from which the DWF was created.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Slawomir_
You can attatch DWF as underlay by typing XREF. But underlay will not export to DGN. I'm still investigating.
pendean
Community Legend
Community Legend
Solución aceptada
No such tool exists, Autodesk or third party.
sjlee
Thank you sooooo much for your reply.
I didn't even know, if the DWF was 3D, it is impossible to load in AutoCAD.
0 Me gusta
sjlee
Thank you for your reply.
There are 2 ways to load DWF file in AutoCAD.
0 Me gusta
sjlee
Thank you for you reply.
It helps me a lot!
0 Me gusta
