AutoCAD Forum
How to convert arcs into several straight lines?
3 REPLIES 3
ltmullen
15225 Views, 3 Replies
I have a giant polyline containing a mix of arcs and straight segments, and I would like to convert all of the arcs into a series of small, straight lines so that I can use the polyline with a plug-in I wrote to use the polyline as a selection polygon.
I tried searching through old forum posts but couldn't find a very good solution--someone mentioned something about WMFOUT and WMFIN but that gave me some pretty weird, wobbly lines as a result and plus it didn't scale things the same when I used WMFIN. Anyone know of some hack that's a LITTLE less hacky than that?
3 REPLIES 3
Patchy
in reply to: ltmullen
hmsilva
pocketmerlin,
maybe this code lead you to the right solution, was written only as a demo,will create a new LWPOLYLINE with the arcs transformed into lines with a length of approximately 1.0 each...
(defun c:test (/ CURVE DST DST1 DST2 DSTCURVE I PAR PAR1 PT1 PT2 PT3 PTLST X)
  (setq
    curve (vlax-ename->vla-object (car (entsel "\nSelect LwPolyline : ")))
    par	  (vlax-curve-getendparam curve)
    par1  0
    ptlst (list (vlax-curve-getpointatparam curve par1))
  (repeat (fix par)
    (setq pt1	   (vlax-curve-getpointatparam curve par1)
	  pt2	   (vlax-curve-getpointatparam curve (+ par1 1))
	  dst	   (distance pt1 pt2)
	  dstcurve (- (vlax-curve-getdistatparam curve (+ par1 1))
		      (vlax-curve-getdistatparam curve par1))
    (if	(equal dstcurve dst 1e-11);; is line
      (setq ptlst (append (list pt2) ptlst))
      (progn
	(setq i	   (fix (/ dstcurve 1.));; 1. is the new segment length at curves
	      dst1 (/ dstcurve i)
	      dst2 (+ (vlax-curve-getdistatparam curve par1) dst1)
	(repeat	(1- i)
	  (setq	pt3   (vlax-curve-getpointatdist curve dst2)
		ptlst (append (list pt3) ptlst)
		dst2  (+ dst2 dst1)
	);; repeat
      ;; progn
    );; if
    (setq par1 (1+ par1))
  );; repeat
  (entmake (append (list '(0 . "LWPOLYLINE")
			 '(100 . "AcDbEntity")
			 '(100 . "AcDbPolyline")
			 (cons 90 (length ptlst))
		   (mapcar '(lambda (x) (cons 10 x)) ptlst)
  (princ)
 HTH
Henrique
bhchar28
I have wanted to do this for a long time.  Finally I made a plug-in.  Please check it out at www.arctolines.com.  It offers some useful options.  It has a command MPO that will allow you to select as many polylines as you like and convert them.
”Boost
