How to convert a recover bak file to a dwg file
No aplicable
Hi there,
For some awful reason a folder was deleted on my computer containing CAD files. I have checked everywhere for the files, a system restore, the recycling, a hidden folder etc and could not find it. Strangely the file still shows up in "Quick Access" tab under file explore. When I click on it is says the file cannot be found.
I was able to find some late backup on one of the cad files under the C// user// app data etc. the photo is shown below of the .bak files. I have tried to rename to created a .dwg file but it does not work. I want to create a drawing from one of these recovery files, is this even possible?
Any help is much appreciated. Thanks!
0 Me gusta
Responder
2.105 Vistas
2 Respuestas
Respuestas (2)
imadHabash
Yes it could be . make sure first that the file extension (.bak ) is appeared >> Click << then rename .bak to .dwg . if you need more help please attache here the file ?
Imad Habash
0 Me gusta
Tiana_Y
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD forum! I'm just checking in to see if you need more help with this. Did the suggestion that @imadHabash provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
0 Me gusta
