How to clip a block with a circle?
Message 1 of 9
Hi All,
I am trying to clip a block using circle, but I need the information outside the circle (it's actually multiple circles). Are there any command that I can use other than WIPEOUT ?
Flora
Replies (8)
Message 2 of 9
rkmcswain
EXTRIM may do what you want, unless you are trying to operate on multiple, different insertions of a block definition.
If you want to use the traditional XCLIP command, then instead of drawing a true CIRCLE, use the POLYGON command to draw a polygon with say, 200 sides, and use that for your cutting edge. Be sure to invoke the "Invert Clip" option.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 9
Alfred.NESWADBA
Hatch with pattern = SOLID and a true-color of 255,255,255 (to make sure it's white when plotted, independent of CTB).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 4 of 9
Johanna_Esteban
Hello @florawa
Taking into account that you do not want to modify your block but if you use a part of it since you may need it in the same file with its original appearance, I will show you XCLIP and the variable XCLIPFRAME.
XCLIP will allow you to start from an edge, delimit what you want from what you do not want to show, and with the variable XCLIPFRAME you control the edge.
XCLIP command
XCLIPFRAME (System Variable)
Watch the screencast.
Although you need a circle, I used a 48-sided polyline based on the circle to select it in the XCLIP command options.
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
Message 5 of 9
jayhar
Hi, @Anonymous
I found the solution see this Video. First Convert Circle to Polyline use .lsp Use command FLATTEN in circle polyline then XCLIP https://autode.sk/2LuapRR
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 6 of 9
rkmcswain
Circle can convert to polyline using Donut inside diameter of donut outside diameter of donut and change width to 0 or draw a circle use boundary [BO] or .lip also available to convert Circle to polyline
Why not just use solution in post #2 of this thread? Use the polygon command, and set the number of sides to something like 200.
Message 7 of 9
jayhar
Hi, @rkmcswain
<<<<Why not just use solution in post #2 of this thread? >>>>
To be continue in post thread, i seen error message "Boundaries With Zero Area are Not Acceptable" you can also see video at .43 sec.
After post the forums i continue to find solution for error message "Boundaries With Zero Area are Not Acceptable"
Then i understand use FLATTEN Command. So i post next forum with Screencast.
Jayhar.M.J
Message 8 of 9
Looks useful for other problems, but unfortunately I want the things inside circle to be hidden.
Many thanks though!
Message 9 of 9
RobDraw
That's great that you clarified that @jayhar didn't understand the question but what about the other posters that did understand and offered viable solutions?
Rob
