How to clear notifications from the Start Tab?
garrisonaw
Message 1 of 12
garrisonaw
On the Start Tab, there are 10 notifications dating back nearly a year. These are useless to me, but their presence on my screen is annoying. But I can't find any way to clear them or to turn them off.
Can anyone help?
Replies (11)
Message 2 of 12
ennujozlagam
in the command prompt type  STARTMODE and set to 0 and see if helps. thanks
Message 3 of 12
cadffm
Follow the link one time (each hint), that's it.
10 notifications sounds like 9 tips you never followed and one program update.
@ennujozlagam
Sebastian
Message 4 of 12
garrisonaw
Thanks, but STARTMODE = 0 would disable the entire Start tab, and that's not what I'm looking for.
Message 5 of 12
garrisonaw
Actually, it's 9 "have you tried" suggestions, and one "see today's top trending how-to videos and tutorials".
If I had wanted to follow the links, I would have done it already. I want to be able to dismiss the notification without following the links.
Message 6 of 12
cadffm
That's a new Level.
But for this I have no answer, except to redefine the Start tab.
A big edit for this not-a-real-problem case.
Sebastian
Message 7 of 12
dany_rochefort
hahaha 🙂
Message 8 of 12
garrisonaw
@cadffm wrote:
That's a new Level.
Adding one button to dismiss a notification is not "redefining the Start tab".
Thanks, but no thanks for your not-a-real-answer.
Message 9 of 12
cadffm
You are wrong,
"Adding one button to dismiss a notification is not "redefining the Start tab".
Adding a button in Start tab would be a redefine design.
But as solution i thought to remove the whole 'Notification' part of the Start tab.
"Thanks, but no thanks for your not-a-real-answer."
? This IS a real answer!
If you don' t understand, it doesn't means that it isn' an answer(and solution)
But perhaps also your secound question was not your real question,
perhaps you real question is:
How to set notifications as read (without reading), by push a button?
And hey,
i think there is a way without hacking the start tab,
but I have no time for you now,
later and back on acad I will take a look for you.
Sebastian
Message 10 of 12
cadffm
So far I am right, it is not controle by CAD Manager Tools,
or perhaps, CMT supress only NEW notifications?
But disabling there would disable it at other places too.
I had  a quarter hour after dinner and checked the way to
- disable the whole Notification part of start tab,
- also I can set each Notifications read/unread
But still I don't know a out-of-the-box-GUi-way.
So for you it wouldn't be an answer?
Then  I am sorry 🙂
Sebastian
Message 11 of 12
garrisonaw
Well, thank you for looking into it further.
Maybe (or maybe not) Autodesk will modify it in a future update. For the time being, I guess I'll just continue to ignore them.
Message 12 of 12
Alfred.NESWADBA
in AutoCAD 2022 you can hide the bar with the annountsments ...
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
