how to change unit from mm to inch
toznal
toznal
I would like to change dimension from mm to inch.
all drawing is in mm.
How can I change to inch? (model and dimension style)
Thank you.
0 Me gusta
Responder
Soluciones aceptadas (1)
2.530 Vistas
1 Respuesta
Respuesta (1)
No aplicable
Solución aceptada
Command -DWGUNITS & follow the prompts on the command line. There are different options for whether or not you want to scale your geometry. You might need to adjust your dimension styles separately, command DIMSTYLE.
0 Me gusta
