How to change the below Location ??
KIMHENGHOR98
KIMHENGHOR98
KIMHENGHOR98
If I move my drawing to a new location, it would fail loading sheets
imadHabash
You can not change the location because it's just an Info for the CAD file that you already select above. For loading CAD files you have to press the above left green button with + sign .
Imad Habash
pendean
Community Legend
Community Legend
You'll need to create a new PUBLISH command's saved DSD if that is what you are asking about.
cadffm
There is no feature to edit your .dsd content, except to rebuild manually.
But .dsd files are plain text files (with .dsd extension),
so you can use a simple texteditor to open your  .dsd to edit the content.
Run a find&replace, save the file (for first tests, saveas a copy) and load your new  dsd in publish command.
It's possible that you will find a tool for this, but not ootb within Acad.
Sebastian
