Anuncios
How to change .SHX font to Calibri font?
No aplicable
I'm trying to change the Cpas.shx font to the standard Calibri font but it doesn't seem to be possible. Any way to work around this issue?
Thanks.
0 Me gusta
Responder
2.029 Vistas
5 Respuestas
Respuestas (5)
WarrenGeissler
You will have to UNCHECK "Use Bigfont" before you can change the font for this style. Be warned though - a BIGFONT uses special characters and these will either disappear or change to a question mark (?). It would be best to get a copy of the font used.
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
tboehler
I believe you need to deselect the BIG FONT check box.
0 Me gusta
No aplicable
This works, but to actually see the change I had to select the text, right click and go to "MTEXT_EDIT" and then select the style I choose.
Idk why I have to go to MText edit and select the text style from there to see the change, but this process sounds correct right?
0 Me gusta
john.vellek
HI @Anonymous,
Unlike Dtext, Mtext allows style overrides which might be causing this issue.  Is it possible to attach a sample file along with the old font? I am happy to see if there is anything that can be done to speed up this font conversion process for you.
John Vellek
0 Me gusta
john.vellek
HI @Anonymous,
Have you worked through the issue of switching the fonts? If not, I am still happy to take a look at your drawing if you can provide it to me.
John Vellek
0 Me gusta
