How to change active text style in Autocad Document from Standard to ISO or other standard just by passing name to any predefined method through C# or Vb.NET?
aakash.parvathini
aakash.parvathini
I'm trying to change active text style in Autocad Document from Standard to ISO or other standard through C# or Vb but can't do it properly.
The current object belongs to AutoCadDocuments class and I'm unable to set current textstyle by name.
Can you please help me.
Why don't you offline the device and re connect it with the Wi Fi because I have done the same last time when faced this issue here in my project.
aakash.parvathini
Can you please read the question again?
cadffm
1. You should ask in the right board for .Net programming -> https://forums.autodesk.com/t5/autocad/ct-p/8
2. You can set variable TEXTSTYLE to change the current style to another one.
   (if you really want to set another style as current)
Sebastian
