How to bring up the old screen menu?
Message 1 of 19
Ok, here is a question for you old-school users of AutoCAD.
Does anyone remember the old screen menu that you used to have in AutoCAD 11 and prior?  It was a black vertical menu that always stayed on screen,  and allowed you to scroll through commands.  I just wanted to show it to a workmate, since he and I were talking about old commands in AutoCAD (he just learned AutoCAD in the last few years).
It used to be that it was still shown as a choice in the Options menu in AutoCAD, but I'm not seeing it there now. Does anyone know if you can still bring that up?
Thanks in advance!!
Replies (18)
Message 2 of 19
dmfrazier
It was deprecated several releases ago (can't remember when, though).
Message 3 of 19
Patchy
That side menu bar with a scroll bar was DOS days.
Then it went to icons
and Ribbons killed the side menu bars.
Message 4 of 19
imadHabash
 if you mean the SCREENMENU , you can get it back by REDIFINE command.
Command: REDEFINE
Enter command name: screenmenu
Command: SCREENMENU
Enter new value for SCREENMENU <0>: 1
Imad Habash
Message 5 of 19
cadffm
@Anonymous
It's hidden since few versions..
;; copy&paste it into your commandline[CTRL+9] or textscrren[F2]
(progn
   (if (and
	 (setq obj(vla-get-Display (vla-get-Preferences (vlax-get-acad-object))))
	 (= :vlax-true (vla-get-DisplayScreenMenu obj))
       (vla-put-DisplayScreenMenu obj :vlax-false)
       (vla-put-DisplayScreenMenu obj :vlax-true)
   (vlax-release-object obj)
;; Or as Lisp command/toggle, command: SCREENMENU
(defun c:SCREENMENU (/ obj)
   (vl-load-com)
   (setq obj (vla-get-Display (vla-get-Preferences (vlax-get-acad-object))))
   (if (= :vlax-true (vla-get-DisplayScreenMenu obj))
Sebastian
Message 6 of 19
Hmmmm….
Doing that makes mine pop up, but it doesn't show the commands in it.  Interesting.
Message 7 of 19
dmfrazier
That just means you have no screen menu content defined in the CUI(s) that are loaded, or if they are defined in one of the CUIs, then your workspace doesn't have any turned on.
Message 8 of 19
If you have it working, can you show me what your CUI has under it?
Message 9 of 19
dmfrazier
Sure.
Running AutoCAD 2018 with an out-of-the-box (default) profile.
First, I REDEFINEd the SCREENMENU command, and then I ran it to turn it on (set to 1).
In CUI, under the ACAD CUI, at the Legacy node, this is what I see:
In the editor, this is what I see (because apparently the screen menu is on by default in the default workspace):
Ahhh... the good old days! 😉
Message 10 of 19
Thanks!  😛
Message 11 of 19
elucas_KWS
This still works in AutoCAD 2024 🤣
Message 12 of 19
paullimapa
Curious if there’s a way to change the text color on the screen menu from the default of black to say white?
Paul Li
IT Specialist
@The Office
Message 13 of 19
dmfrazier
My guess (no time to investigate right now) is that it follows the color assigned in Options, Display tab, Colors button (Drawing Window Colors), Command line, Command History Text:
Message 14 of 19
ruslin
I have the same question too,
Message 15 of 19
paullimapa
Unfortunately doesn’t seem to follow any of those options on the Color selections. I wonder if it’s based on the overall Windows color theme which controls foreground and background color of dialogue boxes
Paul Li
IT Specialist
@The Office
Message 16 of 19
dacatalanV4FK6
Community Visitor
Community Visitor
How does it work in AUTOCAD 2024? The command REDEFINE does not exist, so I cannot show the SCREENMENU
Message 17 of 19
pendean
Community Legend
Community Legend
Are you an LT2024 user by chance? REDEFINE has never been a function in any LT variant to date.
or are you perhaps using an OEM version of 2024?
REDEFINE works fine in R2024.1.2 here for me
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-E2B53E4D-28AE-4F6E-96E4-6FABE3FF823C
Message 18 of 19
dacatalanV4FK6
Community Visitor
Community Visitor
I am in LT2024, I do not know that REDEFINE does not work in that version.
Thanks for the answer!
Message 19 of 19
sjxyz
I have managed to keep the screen menu going through many upgrades, but sadly I can't see it in the CUI under the legacy tab. Is there anyone who would be able and prepared to transfer their Legacy Screen Menu to a new file and share it as I would really likely to change the commands that my menu offers.
