how to bring in linetype from other files?
No aplicable
0 Me gusta
Responder
7.553 Vistas
6 Respuestas
Respuestas (6)
pendean
Community Legend
Community Legend
Copy/paste objects with those linetypes from the source file into the destination file if you don;t want to use ADCENTER command's ability to import all sorts of content between files.
0 Me gusta
mnorris843
I'm sure there's a better way to do it but i make a block from the line with linetype i want, then i insert it into the other drawing.
0 Me gusta
peterm
You can use the design center.
Find the drawing with the linetypes or whatever and just drag and drop the elements you want into your new drawing.
0 Me gusta
No aplicable
how to bring in linetype template instead of single linetype from other files?
0 Me gusta
peterm
You can select, drag and drop all the linetypes in one go.
Alternatively, if you have a blank drawing with all the linetypes in it, you can insert it as a block.
Another way is to make sure your drawing templates contain all the linetypes you typically need.
vladimir_michl
You can also export the original linetype definitions (incl. complex linetypes) to a .LIN file and then use this file in other drawings. See the LINOUT freeware on www.cadstudio.cz/freeware
Vladimir Michl, www.cadforum.cz
