AutoCAD Forum
How to attach XDATA to multiple block objects.
6 REPLIES 6
ballalyash
456 Views, 6 Replies
I want to attach XDATA to a .dwg file which contains over 1000 block objects approximately.
I'm using AutoCAD 2020.
6 REPLIES 6
TheCADnoob
in reply to: ballalyash
Are you trying to attach the data to the blocks or the drawing?
CADnoob
ChicagoLooper
Hi @ballalyash
Plain vanilla AutoCAD can't deal with XDATA because it doesn't read or understand it. You'll need to use either AutoCAD Map3D or AutoCAD Civl3D, both have the capability to read XDATA.
You should download a trial version of the >>Map3D toolset.<<  If you have questions, post them in the AutoCAD Map3D Forum, not this one.
Chicagolooper
ballalyash
in reply to: TheCADnoob
The whole drawing which has different types of block objects. Manually I can attach it one by one, but it'll take forever.
I need to know how to attach it to all the objects at a time.
ballalyash
Sorry, my bad.
My requirement is for individual objects, but xdata should get attached to all the objects present in a Drawing.
pendean
Command XDTOOLS_ADD from XDTOOLS.
-- Alexander, private person, pacifist, english only with translator 🙂 --
Object-modeling _ odclass-odedit.com _ Help
Forma Design Contest
