How to add the "real dynamic quote" to a quote with just tex?
Hello folks!
Here is a small/big problem.
In the past days, I modified handmade the "real dynamic quotes", so now they are just normal texts (when I drag the quote lines, numbers don't change).
So, how can I add the "real dynamic quote" to a quote line like the ones I have now?
Thanks in advance.
Gabriele.
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I am not sure I understand what you mean by "real dynamic quote", can you provide more information or a sample of this to clarify?
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
leeminardi
“This” shows a dynamic quote whereas "this" does not.  If that's what you want to do you could use ASCII characters 147 and 148.  If your keyboard includes a number pad to the right of the main keyboard then hold down the Alt key and from the number pad type 0147 or 0148 and then remove your finger from the Alt key.
lee.minardi
Hi  and thank you for your attention.
I'll try to better explain what I did, so everything we'll be more clear:
1) I created a quote (the one I called real dynamic quote) by clicking the button shown in the pic I attached;
2) Then I cancelled manually the quote and modified it...but now it's not a quote but just TEXT;
3) What I can do now to associate a real quote as point 1) to the "EXISTING LINE with just text?
Hello, I'm sorry but I'm not sure I catched.
Can you please explain the steps I have to do?
Thank you in advance!
