How can I add a scale to the viewport pulldown list?
If you look at the annotation scale and choose it you can select custom and create a new scale.
I presume you are referring to the grip that is new to viewports in paperspace layouts.
That list is identical to the list located in the status bar. To edit this list, the viewport needs to be unlocked. Then click the scale shown to display the scale list flyout. Scroll to the bottom of the list and you will see the 'Custom...' option. Clicking this will display a dialog box where you can add/delete/sort the list.
Hope this helps!
Thank you, Kevin. That was very helpful.
Yes. Thanks.
