How to add new elements to layout from model
warren3QYVV
Message 1 of 17
warren3QYVV
hi,
i have done a drawing and produced the relevant views in layout. i have had to go back into the model and draw some additional new fixings. how to i now get these new element's into my layout?
thanks
gavin
Replies (16)
Message 2 of 17
pendean
Community Legend
Community Legend
@warren3QYVV Do you just wanT to know how to add viewports in your layout?
Or just grip-edit them to make the viewports there wider/taller?
What does "new fixings" mean to the rest of us please?
Message 3 of 17
ianjchap
Hi @warren3QYVV,
If these additions are in the same viewports then they will update automatically. If the new items are in a different location to your current views, then you'll need to create a new Viewport to show these.
The easiest way would be to copy a current viewport, double click through the viewport (making sure it's unlocked) and navigate to the new drawn information.
Using a set scale.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
Message 4 of 17
warren3QYVV
Hi
thanks for your replies. I have attached the drawing for your reference. I had initially drawn the  boxes but after had to add a bolt fixing to the top. this bolt however does not show up on my layout
i hope this makes sense
Message 5 of 17
Brock_Olly
@warren3QYVV
Click the viewport and type VIEWUPDATE or click the icon in the ribbon that says update view
Message 6 of 17
warren3QYVV
im am trying this but nothing seems to be happening
any other suggestions?
thanks
Message 7 of 17
DGCSCAD
Select the PARENT View, then select Edit View from the ribbon. Use sElect (type E) from the options and select the new objects.
AutoCad 2018 (full)
Win 11 Pro
Message 8 of 17
vinodkl
Hello @warren3QYVV
Type in the command "VIEWBASE", select "From model space" to insert the view.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 9 of 17
warren3QYVV
Thanks, the VIEWBASE works to an extent but im not sure if i have explained it properly.
my drawing was complete and saved as a layout in the attached (bolt2.jpg.) i then had to modify it by drawing a bolt (bolt.jpg) is there a way of showing the newly drawn bolt within the existing layout?
Message 10 of 17
warren3QYVV
Basically im trying to add just the bolt to my layout
Message 11 of 17
vinodkl
Hello @warren3QYVV
Please try to use "VIEWUPDATE" and select the view to update it.
Message 12 of 17
warren3QYVV
i have tried this and unfortunately nothing happens
Message 13 of 17
illusionistNUGXG
Maybe a bit unusual if this (drawing-) variable would be 0
...but is VIEWUPDATEAUTO set to 1?
Message 14 of 17
warren3QYVV
yes VIEWUPDATE AUTO is set to 1
Message 15 of 17
Brock_Olly
Which command did you use to create those viewports?
Which version of autocad are you running?
Message 16 of 17
Brock_Olly
I think when creating the viewports you used VIEWBASE command, then used 'select' to create a selection of what you want to display.
When you add the bolt, it's not part of that selection set you previously created.
Go to your BASE view, edit view, select, add the bolt or objects you want and exit.
If you had only one object in your model and you didn't use select, the view would automatically update. I don't work in 3D but I think most people would use one DWG per assembly?
Message 17 of 17
warren3QYVV
its now worked. not sure what i have  done but it is good now.
thank you so much for your help and assistance
