How to add both prefix and suffic to a dimensionstyle
t_orie
t_orie
I want my dimension for a certain drawing to look like this:   < ±1234 >
I tried to achieve this with entering < %%p as a prefix and > as a suffix, but apparently, in dimstyle
definition, you can't have both at the same time.
Selecting a dimension and adding both in the properties window does work, bit it would require me
to change those properties manually after adding the dimensions.
Is there a way to get this done?
Thanks for helping!
0 Me gusta
Responder
Soluciones aceptadas (2)
763 Vistas
10 Respuestas
Respuestas (10)
cadffm
Solución aceptada
Prefix AND Suffix at the same time is usually not a problem, but in your case
you are using characters which are special controle characters in dimension texs
and this became trouble.
Solution:  Check out the unicode codes of one or both chars and add them to your dimstyle.
Sample for ARIAL.ttf
Sebastian
Valentin-WSP
Solución aceptada
@t_orie ,
Prefix:  < [Hold Alt+0177]
Suffix:  >
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
cadffm
@Valentin-WSP cool, but
Thats the usual way someone whould try it, or like TO tried it.
But on my side (and it looks like for TO too),  the suffix and prefix content disappears after type-in (in dimstyle dialog)
and by using this dimstyle, just the suffix part appears in you dimension.
REC from ACD2021
Sebastian
0 Me gusta
Valentin-WSP
@cadffm ,
Yes, the prefix and suffix content disappears.  However, you can still save the style - and use it.
Emilio Valentin
cadffm
You're wrong.
YOU can use it with the wanted result,
WE can't.
That's the reason of this thread, as you can read abouve and see in my video/gif.
(tried 2021 ACD $ C3D)
Sebastian
0 Me gusta
cadffm
Hi @t_orie
you marked post#3 as Solution, is it working on your side or why?
On my side it isn't working :cara_de_decepción:
Sebastian
0 Me gusta
t_orie
it is the solution i tried last and it worked, same as yours but it looks less complex.
thanks for the solutions!
cadffm
lol,
for @t.ori just < %%p > doesn't work and I guess it is the same for @Valentin-WSP ?
<[ALT]+0177> works for you both
and for me, both ways doesn't work, WTH?
hmm.
Sebastian
0 Me gusta
Valentin-WSP
@cadffm ,
That's unfortunate, it works fine in both AutoCAD and C3D.
Emilio Valentin
cadffm
Thank you for testing,
I don't know why it doesn't work here [tried ACD C3D, German / English, OS lang to Eng instead Ger].
Luck: I don't need it know and I don't have time to search for the problem.
THANKS
Sebastian
