How I enter commands have changed on me
No aplicable
My AutoCad crashed yesterday and when I went back to work using it the way I enter commands changed. Before if I wanted to move a line I could highlight the line and use the move command to move the line. Now when I highlight the line and use the move command it will deselect the line that I had highlighted. So now to move a line I need to use the move command and then highlight the object that I want moved. Is there a setting that maybe changed when it crashed yesterday? It also does this for every command such as rotate, copy, etc.
0 Me gusta
Responder
Soluciones aceptadas (1)
457 Vistas
3 Respuestas
Respuestas (3)
Patchy
Solución aceptada
PICKFIRST = 1 should fix it.
0 Me gusta
rkmcswain
Set PICKFIRST = 1
Patchy
Check your FILEDIA too, crash can change it to 0, make it 1
0 Me gusta
