How i can change all attribute text height in Autocad
Message 1 of 13
How I can change all attribute text height in AutoCAD, as I received xref block file, I can do 1 by 1 but it's time consuming,
kindly advice
Replies (12)
Message 2 of 13
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Run command _BEDIT, select the block which contains the attribute you want to change.
Within the blockeditor you can then select the attribute and modify it's size, close the blockeditor with saving (now you are back in modelspace), run command _ATTSYNC, type in the blockname to synchronize (same blockname you had opened in blockeditor) and let _ATTSYNC do it's job to update all insertions with that name.
You'll have to do that once for every block-definition (but not once for each insertion) 😉
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 13
imadHabash
Hi and Welcome to AutoDesk Forum,
by BATTMAN either you can EDIT the Heights then Sync will finish the job in one place.
Good Luck..
Imad Habash
Message 4 of 13
The BATMAN solution is a poor one.
AutoCAD should have a utility like AutoCAd Electrical where one can change the properties of many attributes without having to sync the attributes.  Syncing the attributes changes the position and rotation back to the block default, very frustrating.
Brett
Message 5 of 13
Wow saved me a ton of time. This helped!
Message 6 of 13
pendean
Community Legend
Community Legend
@Anonymous Let Autodesk know about it here https://www.autodesk.com/company/contact-us/product-feedback
Message 7 of 13
lbellino4
@imadHabash  Didn't know about this command, thanks for this tidbit!
Message 8 of 13
dm0144
Hi, I am having the same issue here.
I can only change the text height only to one attribute at a time.
How can I change the text height of all attributes at once? Is it possible to select multiple attributes at once and than edit the property?
I tried CTRL and select multiple or SHIFT on the first and than the last or CTRL+A to select all of them but it didn't work.
Any solution?
Message 9 of 13
Alfred.NESWADBA
Inside the block-editor? Just select the attributes you want to modify and change the height in the property window.
Doesn't this work?
- alfred -
Alfred NESWADBA
Message 10 of 13
dm0144
YES! IT WORKED!!
Message 11 of 13
salter49W7T
How do you do it in autocad electrical?? Pleaseeeee tell me this will save me weeks of work.
Message 12 of 13
salter49W7T
How do you do this in autocad electrical?? Pleaseee tell me this will save me weeks of work.
Message 13 of 13
pendean
Community Legend
Community Legend
If you cannot do what you need in the solution already posted, you'll want to ask in the ACADELECTRICAL forum for guidance, here is the link there https://forums.autodesk.com/t5/autocad-electrical/ct-p/2035
