How do you unblock a block without eliminating drawing?
Message 1 of 10
I created a block and want to "unblock" it and keep it as a plain and editable drawing in model space as well as in paper space
How do you do this - the edit key only lets me edit the drawing and then returns it to the block image
Replies (9)
Message 2 of 10
Patchy
Use GROUP, you can add or remove any parts in a group when using PICKSTYLE (Ctrl+H) with a group.
Message 3 of 10
Kent1Cooper
EXPLODE it, not in the Block editor, if that's where you're trying to un-Block it, but out in the drawing where you can select it as a unit in the Explode command.  Or am I misunderstanding something?  It is possible in newer versions to define a Block so as to not allow Exploding, so watch for that.  I don't think that can be an issue if it's an external drawing file that you have Inserted as a Block in another drawing, but I can't tell from your question.
Kent Cooper, AIA
Message 4 of 10
like you said i have the newer version and i am not able to do so.. is there any other alternative?
Message 5 of 10
pendean
Community Legend
Community Legend
@Anonymous we don't know what you mean, what can you not do, and what "newer" version is not letting you try the tips above? can you elaborate in more detail please?
Message 6 of 10
dbroad
Bedit the block. Open the properties palette. In the allow exploding property, choose "Yes" and save the block. Then explode the block insertions and optionally purge the block definition.
Generally exploding block references is a bad idea.  Why do you want to do it?
Architect, Registered NC, VA, SC, & GA.
Message 7 of 10
erietta99
Community Visitor
Community Visitor
Recently i used the burst tool to edit each segment of a block, and it didnt erase the entire thing like the tool explode did. Hope this helps
Message 8 of 10
AnneElise.BoltonAZWRL
BURST worked best for me too!! When I tried 'Explode' it kept deleting the entire block
Message 9 of 10
Kent1Cooper
... also in response to the Message before that....
I wonder whether having it all disappear when Exploded could be simply that the parts of the Block are drawn on Layer 0 [common practice], and that Layer is turned off or frozen, but the Block was Inserted on some other Layer so that it was visible.  The parts would disappear because of reverting to their original Layer [which they would not from using Burst], but they would still be there, and would re-appear when Layer 0 is thawed/turned on.
Kent Cooper, AIA
Message 10 of 10
youre right!
