how do you reset the view to 2d after an object was rotated
darenrr
darenrr
so I rotated an object in 3d and it seems to have fallen off of the x y z axis rotation
my other 2 objects are still in the same xyz plane
so when i hit top view, objects b and c show the top view but object a has an angle view
ive attached an image.
how can i remove the angle and just show a top view?
thanks
leeminardi
If you want to rotate the object so that it is aligned to the WCS use 3DALIGN.
If instead you want to view the rotated object straight on then set a UCS such that its XY plane is parallel to the surface you want to view and then give the PLAN command.
lee.minardi
