How do I trim a 2d where it cuts into a 3d model?
Message 1 of 12
If I have a 3d model (say a cube) and a 2d line is passing through it, how do I trim the 2d line where it enters the 3d cube?
Replies (11)
Message 2 of 12
If I have a 3d model (say a cube) and a 2d line pointing towards one of the faces, how can I extend the 2d line touch the face?
Message 3 of 12
Tomislav.Golubovic
I'd draw a construction line and then trim to that then delete the construction line
Message 4 of 12
devitg
Draw a line from any cube side line perp to the 2d line  that is through the cube , trim as need , erase the perp line
Message 5 of 12
leeminardi
If the 3D solid is more complex than a cube you could:
  1. Make a copy of the solid.
  2. Draw a small circle
  3. Sweep the circle along the line creating a cylinder.
  4. Subtract one of the two solids from the cylinder.
  5. Move the end of the line to the end of the truncated end of the cylinder.
lee.minardi
Message 6 of 12
Alfred.NESWADBA
here are 2 good suggestions >>>click<<<
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 7 of 12
Alfred.NESWADBA
here are 2 good suggestions to find intersection point of line and face ...  >>>click<<<
- alfred -
Alfred NESWADBA
Message 8 of 12
SEANT61
Another method to deal with complex geometries.
Line Trim To Surface | AutoCAD Mechanical | Autodesk Knowledge Network
May your cursor always snap to the location intended.
Message 9 of 12
dbroad
The method demonstrated in the link @SEANT61 posted used imprint.  Using that technique, start the imprint command, select the cube, then select the line.  Then use the break command, select the line, enter "F" for first point, and then use osnap to select the 1 or 2 points or the line created by the imprint command depending on how the original line and cube are related.
Architect, Registered NC, VA, SC, & GA.
Message 10 of 12
Many thanks, I really appreciate the rapid help given by you all :0)
Message 11 of 12
Message 12 of 12
