How do I stop intersection snapping to multiline text
Message 1 of 8
When I am trying to move or copy something near a multiline text, the object seems to intersection snap to the nearest corner of multiline text. How do I stop this from happening, I see no use in snapping to the corner of the multiline text? I have tried using OSNAPNODELEGACY and this did not stop my problem from occuring. Please help.
Replies (7)
Message 2 of 8
cadffm
Intersection, not BASEPOINT/INSERTIONpoint and not NODE ?
Please upload a sample DWG with ONE Mtext and a picture while the osnap mark is visible.
Sebastian
Message 3 of 8
GrantsPirate
Turn NODE off in your selection of running Osnaps.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 4 of 8
vinodkl
I think you are confused with NODE and INTERSECTION. Its actually the NODE snap which is not letting you to move /copy the object near to the MTEXT. Try turning off NODE snap from OSNAP.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 5 of 8
Apologies I may be incorrect. I believe the osnap is an intersection snap, not a node snap (the snap emblem shown when it snaps is a little green cross). I already have node snap turned off. Intersection snap is very useful so I would like to keep it on but is there any way I can modify the intersection snap so that it does not snap to the corners of the multiline text box?
Message 6 of 8
cadffm
"CADffm: Intersection, not BASEPOINT/INSERTIONpoint and not NODE ?
Please upload a sample DWG with ONE Mtext and a picture while the osnap mark is visible."
I forgot to draw another line, so there wasn't an intersection situation, lol.
You are right and every MText will show this "problem". (I never had a problem with this fact.)
Sorry, i think there is no option to disable this.
Sebastian
Message 7 of 8
SSNE302
(removed)  see below
Message 8 of 8
SSNE302
Found this post while fighting with ACad on this issue. I have searched and dug through settings to try and figure it out, to no avail. But I did find some interesting info, it seems to be related to the mtext columns or something. NOT anything to do with Node. See my reply here:
https://forums.autodesk.com/t5/autocad-forum/text-snap-in-2016/m-p/13440221/highlight/true#M1152399
