How do I select only a line and not the objects around it?
Jesseaboyd
Message 1 of 8
Jesseaboyd
In this picture I have drawn lines around the windshield frame. I want to select them so I can make a surface to make a windshield.
However, I cannot select them as autoCAD will only select the larger objects around them. No matter how much I zoom in I cannot get the precision to select only the lines and not the surrounding objects.
Accepted solutions (3)
Replies (7)
Message 2 of 8
beyoungjr
Create a new layer for 2D stuff or test work.
Select the objects you wish and don't worry about whatever else selects.
Once selected you can right click and choose Properties.
In Properties you can narrow your choice in the top list to Lines or Polylines.
Now you can place your lines on your new layer in Properties.
Make that layer current, turn off the other layers, and work with your lines.
Hope that helps.
Blaine
Blaine Young
Senior Engineering Technician, US Army
Message 3 of 8
Kent1Cooper
When you pick in a place where there are multiple objects to choose from, do you not get a box like this?
If not, read about the SELECTIONCYCLING System Variable, and set it as you desire.  You can pick the one among the multiple objects that you want, either in pre-selection or within a command asking for object selection.
Kent Cooper, AIA
Message 4 of 8
Johanna_Esteban
Hello @Jesseaboyd
A simple way is to use FILTER, you can select the entity type than need, in this case like this:
1. Search in the list polyline.
2. Add to list
3. Apply, then you will leave the box and you must select or cover the area for the entity to take, as we only look for the polyline, it does not matter if you cover more than the account.
The polyline should be selected and, with it selected, you go to ISOLATE (4) in the lower right part of the screen to isolate it and make the surface you need, when you finish with it and you finish the isolate (5) so that everything returns again.
Success!!
Johanna Esteban
Autodesk Expert Elite | Autodesk Certified Professional | AutoCAD Customer Council (Beta Tester for Windows & Mac)
¿Te ha parecido útil este post? ¡Dame Kudos! 😉
Si ha sido resuelta tu inquietud, selecciona 'Marcar como solución' para que otros usuarios la encuentren fácilmente.
Message 5 of 8
LyleHardin
SelectionCycling is a good tool to know about.
But, you can also turn your view to 2D Wireframe and it will allow you to select lines. For some reason, when shaded, AutoCAD tends to select solid objects before the simpler objects.
Message 6 of 8
Jesseaboyd
Thank you. This is what I ended up doing.  🙂
Message 7 of 8
Jesseaboyd
Thank you! I learned a new tool today!
Message 8 of 8
Jesseaboyd
Thank you for teaching me a new tool to put in the arsenal!
