When you are saving your blocks for use in AutoCAD, do not save them in the same directory that AutoCAD is installed in. Save them on a server, or something like that for sure. Otherwise when you reinstall AutoCAD it will delete the folders. That said, you probably already do that, so here are a few other possibilities.
In the AutoCAD options, there is a File tab. This tells AutoCAD where to look for resources. Go into the top option Support File Search Path, and add the directory that your blocks are located in.
So if it's trying to insert a block name that it's forgotten the path to, it will search that directory before yelling at you that it's lost.
The last possibility is that you may have moved the blocks after they had been used. This is a typical error for Tool Pallets, and I know you didn't say that's what you were using, but it's a possibility I guess!
