How do i display decimal plot scales in the print options in 2014 LT
Message 1 of 8
I am trying to scale A0, A1 drawings down to A2, A3 respectivley for printing and whilst I am aware that I can do this through setting a custom value of 1mm = 2 units I know from that this should be selectable from the drop down menu, however this is only showing imperial scales.
Drawing units are all in decimal as is the default plot scale for the drawing.
Any help would be appreciated.
Replies (7)
Message 2 of 8
Alfred.NESWADBA
Try to turn sysvar MEASUREMENT to 1, does that help?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
Hi Alfred,
Unfortunatley not.
Tim
Message 4 of 8
Alfred.NESWADBA
when you look to the paper size within the plot-dialog ... have you selected a paper size with mm or with inch as unit?
- alfred -
Alfred NESWADBA
Message 5 of 8
Paper sizes are all in mm. I have attahced a screenshot for ease.
Message 6 of 8
Alfred.NESWADBA
Within your screenshot I don't see anything based on imperial units.
- alfred -
Alfred NESWADBA
Message 7 of 8
Apologies new screen shot showing the imperial scales attached
Message 8 of 8
Alfred.NESWADBA
run command _SCALELISTEDIT and create the scales you need in the drawing and you'd like to show up.
If you want to have your predefined set of scales you can start command _OPTIONS ==> tab "User Preferences" and edit your default scale list ... this gives you the option for every drawing you open to use _SCALELISTEDIT with RESET and your drawing is updated with your defaults.
- alfred -
Alfred NESWADBA
