How do I create/modify these custom aliases/hotkeys/whatever?
avannoyWQW8P
Observer Observer
avannoyWQW8P
Observer
Observer
Someone customized the AutoCAD I use at work using some alternative method of modifying command aliases, and I can't stand it!
My main issue is that when I type C, because that is COPY in my pgp, what actually happens seems to be COPYM.  I have exhausted my patience trying to figure out what they did to create this situation pictured below.
jskalaXDDX5
cadffm
a) Are we talking about plain AutoCAD or AutoCAD LT ?
b) If yes
     What I see is not your .PGP (but I don't know your .ogo, with potential issues).
     Check out what .pgp is in use.
Ribbon MANAGE, Panel Customization, Edit Aliasses
Is it yours? if not: run file SAVEAS to check out the folder and file name.
Best solution: Talk to your (c)admin!
This is the best choice first, second and third
otherwise: Do you have rights to (save the current one), override it with yours.
Sebastian
pendean
Community Legend
Community Legend
They used a LISP, which will always override any PGP entries not matter how hard you try: looks like you will need to go ask that person for help, not here.
Or the actual problem is you just need to change this back to what it was/what you want:
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-BB3CED8E-4FA7-492A-8229-77A9021F67D7
paullimapa
Reset AutoCAD back to the original defaults
Paul Li
IT Specialist
@The Office
avannoyWQW8P
Observer
Observer
Thank You! I figured as much, but have no experience with LISPs to be sure.  One of Many frustrations of working within a customized AutoCAD package bought by my company without included support. I'll just have to work around it.
