how do I change the size of the blocks palette?
mkhudson
mkhudson
When my blocks palette is open it takes up more than half the screen. This is not useful especially since I use list not icons. However I cannot adjust the size of it as I can with other dialog boxes. What setting or command am I missing?
thaydenCJMLL
Try re-sizing at the BOTTOM LEFT CORNER ... it shouldn't matter if it's docked or not....
ETA: If the Blocks Palette is on the LEFT SIDE of your screen, you'll need to grab at the LOWER RIGHT CORNER of the palette to resize it.
mkhudson
Thank you! Apparently I had to be very precise in grabbing that corner.
pendean
Community Legend
Community Legend
We can't see what you see @mkhudson Can you share a screenshot of your entire AutoCAD program window with the problem palette fully visible please?
mkhudson
Already fixed thanks to thaydenCJMLL. Thanks.
