How can I move dimension lines?
No aplicable
I need to make the dimensions vertically (like the red arrow shows it) and whenever I select the "aligned" dimension it does the same thing like the linear one (green arrow).
0 Me gusta
Responder
Soluciones aceptadas (1)
2.283 Vistas
7 Respuestas
Respuestas (7)
Alfred.NESWADBA
You need then to set the UCS to the plane you want to have the dimension drawn on (take care that dynamic UCS is not active) ... then create the dimension.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
No aplicable
I have UCS on, still nothing.
0 Me gusta
Alfred.NESWADBA
>> I have UCS on,
Can you please upload the dwg-file?
- alfred -
Alfred NESWADBA
0 Me gusta
ara_neresesian
Solución aceptada
Hi
use dimedit. Oblicue  and make it aligns to the vertical line.
good luck
Alfred.NESWADBA
>> I have UCS on
"ON" does not help, it needs to be defined to the plane you want to have the dimension on...
- alfred -
Alfred NESWADBA
No aplicable
late at night I managed to find a video that solved my problem - https://youtu.be/6reJsWxvGyM?t=396
We haven't come to 3D drawing yet, but thanks for taking your time and making a video!
0 Me gusta
No aplicable
Hello, I've already found out about this but I will mark it for others to see, thanks :cara_que_ríe_con_la_boca_abierta_y_los_ojos_sonrientes:
0 Me gusta
