Message 1 of 8
Like component name label, Size label
I create reports using Report Creator. If I want to add a new label to a report that is not available in the field list, how can I create and add that new label?
are you using plant 3d?
Imad Habash
@akshay_kumarRF258 wrote:I create reports using Report Creator. If I want to add a new label to a report that is not available in the field list, how can I create and add that new label?
There is no REPORT CREATOR option in plain AUtoCAD, the topic of this forum. Are you using a different AutoCAD program? Or are you using a 3RD PARTY ADD-ON?
You might want to start by looking through this Autodesk support article and then download the reference pdf ...
Andy
Hi @akshay_kumarRF258 ,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
