how can I create a 3D channel with varying height and width
Elahotahari
Observer Observer
Elahotahari
Observer
Observer
hello guys
I am new at AutoCAD, so I've got a question. I want to model an open channel which its height is descending and the width of it widens from upstream to downstream.
I will attach the top view and front view.
can anyone help me with this?
I want a solid to export as a stl file to work with Flow3D.
thank you all.
dany_rochefort
@Elahotahari
- Draw both your 2d shapes using a closed polyline
- Extrude both your shapes to the correct 3rd dimension
- Rotated3d one you your shapes and correctly place it intersecting the other shape
- Use the intersect to merge both 3d shapes into 1 shape
- Use the solidedit command, to shell out your 3d in to create your open channel
Elahotahari
Observer
Observer
thanks a lot, dany
