how can i change the 3d object's scale 1,1,1 without changing object's size
hello, guys.
i have a problem with 3d object's scale.
i have to merge many 3d object(are drawn by other people) into one cad file.
but every object's scale is diffrent.  when i try to convert DWG-> DGN(microstation) -> nwd(navisworks) , some object's size is diffrent with CAD file.
anyway... i want to change the 3d object's scale with remaining object's size.
i refered to this post (https://forums.autodesk.com/t5/autocad-forum/reset-blocks-to-1-1-1-without-rescaling/m-p/3648714#M19...)
but i don't know how to change the scale in BEDIT. thank you for read my post, and apologize to my poor english .
imadHabash
in your case , you have to make reference to determine the scale factor for each different 3d objects. since we don't have any image about what you're talking about , please try to check this AKN article that may help . >> Click <<
Imad Habash
At leftside picture, chosen object is merged DGN and DWG file (It seems to be merged well, but as shown in the right picture, an error occurs in NAVISWORKS because the scale of each object is different.)
So, do I have to modify the scale for each object?
I want to modify the scale in CAD, keeping only the object size.
It may be a silly question, but I am looking for a possible way.
Thanks for the answer.
