Home PC vs Office Workstation: Better Specs, Worse Performance
clay.fritz
clay.fritz
Good afternoon everyone,
I recently installed Autocad 2020 on home PC. I'm working on the same models, drawings and other files there that I do on my office workstation. However, the performance on my home PC is much worse than the workstation despite having (at least on paper) much better specs. See a comparison of their specs is below. (I would also like to note that I do realize that the GPU on my personal PC is not "certified graphics hardware".)
Is anyone able provide some insight into why, or how I could improve performance on my home PC? Thanks for the help!
         Workstation                           Home PC
OS       Windows 10 Enterprise             |   Windows 10 Professional Edition
MB       Dell K240Y (Precision Tower 5810) |   Gigabyte B450 Aorus Pro
CPU      Intel Xeon E5-1620 @ 3.5GHz       |   AMD Ryzen 7 1800X @ 3.6GHz
Ram      16gb                              |   16gb (8gbx2) DDR4-3000
GPU      NVIDIA Quadro K4200               |   GeForce RTX 2060
         711MHz clock w/ 4GB vram          |   1680 clock w/ 6GB vram
Display  Three Monitors @ 1820x1200        |   Single Monitor @ 2560x1400
natasha.l
Hello @clay.fritz
This maybe be more of a maintenance related issue. Try giving these step by step instructions a try first on how to improve AutoCAD performance on your home PC.
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Tomislav.Golubovic
AutoCAD is a single threaded application, and the GPU doesn't mean squat unless you're going to be rendering.
I did a benchmarking post on my site, have a read. My Xeon was always better for CAD, whereas my WS63 was always better with gaming benchmarks.
https://technexus.com.au/index.php/2019/01/20/benchmarking-my-pcs/
SeeMSixty7
Hard Drive?
Is the workstation using an SSD drive and the home system traditional drive?
pendean
Community Legend
Community Legend
You wrote: >>>.. the performance on my home PC is much worse than the workstation...<<<
That tells us nothing: can you elaborate?
Also:
- Where /how are the files being accessed at home? WHere are the stored?
- What are your DWG file sizes?
- WHat format DWG are the files saved to?
- 2D, 3D?
- Note exact AutOCAD versions being used at both locations as listed by ABOUT command?
Your PC specs alone mean nothing to anyone.
