Hollow Text in Hidden Display Style
CrazyIvan
CrazyIvan
Is there a way to make text print solid when in Hidden Display Style?  Thanks!
paullimapa
in this case I would have placed the labels in Paper space then it won't be hidden.
Paul Li
IT Specialist
@The Office
CrazyIvan
I know that works, but these are standard details that get referenced into multiple projects.  To avoid having to make the drafter do extra work and move the notes to Paper Space, it would be easier to be able to not have hidden text.
paullimapa
Here's a trick you can try. Make sure the Labels & Text are on separate layer than the 3d object.
Then in Layout have 2 Vports looking at the same view one on top of each other
The Vport with the Labels & Text will have the 3d Object layer VPLayer Frozen.
The Vport Shade Plot will be set As Displayed
Move the Vport with the 3d OBject to the Front or move the Vport with the Labels & Text to the Back
Do a Plot Preview & you should now see the solid Text as well as the 3d Object
Paul Li
IT Specialist
@The Office
CrazyIvan
Yes. This is a good idea.  Thanks!
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
