Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Hindi Font from Dwg to pdf
akshit.jain
akshit.jain
Hello
While saving dwg file to pdf or printing hindi fonts are not appearing correctly
Replies (9)
imadHabash
make sure from your Custom Properties ( plot dialog )  that you select "Capture All" . or from your PDF options >> Font Handling .
Imad Habash
akshit.jain
I tried doing the same but still same. Do you have hindi.shx file
pendean
Community Legend
Community Legend
SHX font? You need to set font capture to NONE.
akshit.jain
Where is that option , from where i can do that?
pendean
Community Legend
Community Legend
akshit.jain
It did not work , please refer to below attachments and pls how it is printing.
vinodkl
Hi Ak****,
Please attach the drawing, so that we can help you out.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
I have seen same problem please give solution. Urgent or contact no.
akshit.jain
You can have hindi.shx file . This is the easiest solution.
