Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD Forum
Hindi Font from Dwg to pdf
9 REPLIES 9
Message 1 of 10
akshit.jain
3687 Views, 9 Replies
Hello
While saving dwg file to pdf or printing hindi fonts are not appearing correctly
9 REPLIES 9
Message 2 of 10
imadHabash
in reply to: akshit.jain
make sure from your Custom Properties ( plot dialog )  that you select "Capture All" . or from your PDF options >> Font Handling .
Imad Habash
Message 3 of 10
akshit.jain
in reply to: imadHabash
I tried doing the same but still same. Do you have hindi.shx file
Message 4 of 10
pendean
SHX font? You need to set font capture to NONE.
Message 5 of 10
akshit.jain
in reply to: pendean
Where is that option , from where i can do that?
Message 6 of 10
pendean
Message 7 of 10
akshit.jain
It did not work , please refer to below attachments and pls how it is printing.
Message 8 of 10
vinodkl
Hi Ak****,
Please attach the drawing, so that we can help you out.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 9 of 10
I have seen same problem please give solution. Urgent or contact no.
Message 10 of 10
akshit.jain
You can have hindi.shx file . This is the easiest solution.
AutoCAD Inside the Factory
