Highlighting single line in 3D solid
No aplicable
Is there a way I can only highlight and edit the lines of this 3D solid without highlighting the entire thing when I mouse over it?
https://gyazo.com/11110af2fac6e2b4b1b7b28a078e55ab
Right now, when I mouse over a line, it highlights the entire thing. But I want to edit individual lines, how would I do that?
0 Me gusta
Responder
335 Vistas
2 Respuestas
Respuestas (2)
vinodkl
Looks like a block to me than a 3D solid. Try using the command "EXPLODE" on the object to explode the block and work with each element.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
Alfred.NESWADBA
When you use left-mouse click, then you get the whole 3D-Solid selected.
But you can use <CTRL><Left-mouse click> to get sub-entities of the object selected.
Please find >>>here<<< more details about sub object selection.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
