HOW HIDE OBJECT UNDER ELEVATION?
OR IS THERE VIEW RANGE LIKE REVIT
IWANT TO PUT FLOOR PLANS IN DIFRRENT ELEVATION AND WORK IN ONE
Hi @the_ameral,
You could place objects on different planes (along the Z axis for example), but it does not have a feature like View Range in Revit. From how I understand it works, something similar might be able to be achieved using layers, blocks, or Xrefs.
There may be a similar feature in AutoCAD Architecture, you can reach out to that community here.
If a post answered your question or resolved the issue, please click the Accept Solution button.
Likes are always welcome.
All the best,
Hi, how about a section plane?
Gustavo Ubriaco Contreras
Also you can use some like section box in revit, here is volume option
@the_ameral are you assuming AutoCAD automatically generates 3d content/elevations for content you draw in plan?
Only move the central line marked with +z- to the desired z elevation, then you can adjust the grips enclosed in green circles, all inside the box is visible, remember use the volume option
Only works with 3d elements, I thought you was working in a 3d model.
