Hide dialog box with insert command
chorch123
chorch123
does anybody know how to hide the dialog box when inserting a block?
I'd like to do commands line in order to read directly a .txt because I have to insert hundreds of blocks.
I tried filedia, cmdia, attdia and attreq variable systems but nothing happened.
Many thanks in advance
Jorge
imadHabash
how about  -INSERT  command ?
Imad Habash
cadffm
Which dialog?
The INSERT dialog will not appear while you start the command in automation,
but if you like to try it by hand, use the commandlineversion command: -INSERT
 filedia
the standard filedialog, useless in automation
cmdia,
rarely used, but not for the Insert dialog
attreq
important for block with attributes (dependent on there properties). Should Acad ask for Attrib-values or not..
attdia
important if attreq variable is turned on. Should Acad open a dialog window or asking in the commandline for Attribu-values
Sebastian
chorch123
Perfect!
Many thnaks!
