Good evening all! I tried to open my instructor file to do the assignment, but it came out blank. It seemed like the file was used in another program that I didn't have access to. Can you guys help me with this? I tried looking around Youtube and searching for the error, but so far, only 404 errors (outdated page).
Error message:
The drawing you have opened or referenced contains
custom objects created by an unavailable ObjectARX
application. You do not need the original application
to display proxy representations of objects that were
saved in the drawing. However, many manufacturers,
including Autodesk, provide object enablers that also
allow you to edit these custom objects.
Visit the AutoCAD Object Enabler Assistant web
page to locate Autodesk object enablers or contact the
software publisher about object enablers for other
applications.
Missing Application : AeccvBase 130
Product Desc: Autodesk Civil 3D
Company: Autodesk,Inc.
WEB Address: www.autodesk.com
Total Number of Proxies : 11
Number of objects (no graphics) : 11
Number of entities with no graphics : 0
Number of entities with bounding box graphics : 0
Number of entities with real graphics metafile : 0
Missing Application : AeccLand130
Total Number of Proxies : 456
Number of objects (no graphics) : 456
Missing Application : AeccBuildingSite 130
Total Number of Proxies : 2
Number of objects (no graphics) : 2
Missing Application : AeccHydrology130
Missing Application : AeccPlanProd130
Solved by w0481161. Go to Solution.
Solved by TheCADnoob. Go to Solution.
looks like you need the Civil 3D object enablers
CADnoob
I installed the Civil 3D Object Enabler 2022. It's still not working..
It worked when I followed this instruction! Thank you Mr.Noob!
2023 and later versions
For AutoCAD Plant 3D 2023 and newer versions the Object Enablers need to be downloaded from the user's Autodesk account:
