Okay, so I am a drafts person and I use Revit to draw my houses. When I start drawing I load in a Feature Contour Survey that was produced by the land surveyor. Sometimes I can click on the loaded CAD file (in Revit) and it automatically creates topography, sometimes not and I just have to place points at all the spot elevations and type in the elevation data. I have AutoCAD and sometimes have to tweak some info in CAD so it imports properly into Revit and I have noticed that sometimes the Crosses that mark the spot elevations have a 'Z' value that equals the noted spot elevation.
My question is, is the data collected from a Site Survey actually entered directly into AutoCAD initially or is it taken from another program and imported into AutoCAD and then additional lines for fences, driveways etc. are drawn in. When there is a cross but the Z value is 0 is there a way I can enter the spot elevation value and Revit will then recognize it when imported and make 3D topography?
I unfortunately have no one at my disposal that is proficient in this field to help me at work. If the questions I am asking are more complex than expected, if anyone could suggest an avenue to explore to learn more about this area. I have tried scrolling through the forums and watching You-Tube tutorials but just cannot seem to find the specific answers.
Many thanks.
