Help With Pasting Multiple Instances at Once
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am working in a drawing that has multiple blocks. For example, multiple motor blocks. I would like to paste a disconnect for each motor at the same base point on each motor block (the top corner for instance). I know I could edit each block to include the disconnect, however is there a way to copy with base point and then paste where it applies to all the blocks? The blocks are the same, as they all get selected when using 'select similar'.
For Example: If I have three blocks below, and I would like to paste the circle on the top right corner of each of the other 2 blocks. Can that be done without having to select the top right corner of each block? Assuming the blocks are identical. This is a simple example, but I am dealing with many identical blocks.
Any assistance would save me a lot of time.
