Anuncios
help with blurry fonts in PDF
No aplicable
I`m having a mare with blurry fonts.
I`m using DWG to PDF to output my works, the font i`m using is the SHX ROMANS as it it nice and crisp when i print it.  however, the PDF looks very blurry to the point you cannot read it until you zoom into 125% on the pdf viewer.
I`ve tried changing the capture font to geometry and it made no difference.  Increase dpi made no difference.  I originally changed from tt arial as it printed out fat and illegible at height 1.35 metric (too small maybe for A1).
I have just gone through the long task of changing all of the fonts on my template individually as the styles don`t seem to want to change the font.
I`m using AUTOCAD 2016 LT
any help appreciated
ps - I`M PRETTY NOVICE
Tom
0 Me gusta
Responder
851 Vistas
2 Respuestas
Respuestas (2)
TheCADnoob
If it prints fine and is fine when zoomed in, this is a display issue and not anything with AutoCAD.
Check this out and see if it helps : https://answers.acrobatusers.com/How-to-fix-blurry-font-when-opening-PDF-files-with-Adobe-Reader-X-q...
CADnoob
0 Me gusta
pendean
Community Legend
Community Legend
Post your actual PDF: otherwise it appears your pdf viewer display settings are at fault in your screenshot.
0 Me gusta
