Help with BCOUNT, ATTRIBUTE, DYNAMIC BLOCKS
So for my job we have a massive selection of shelving bays from different sizes that need to show their size in the middle of the block with text ex: "24x96" so I created a dynamic block that can be any size wide and length. Than you double click on the text and type in whatver you made the block to. The problem is that when I do a BCOUNT it doesn't tell me how many shelving units of each width and length I have like it would if it each size shelf was it's own block. Is there a way with attributes that work with dynamic blocks and bcount where this can be done or some other way?
Example: 42 (24x96) Blocks
               23 (44X96) Blocks
                 4 (32x54) Blocks
dbroad
BCOUNT is an Express Tool, written long before dynamic blocks became available.  Have you tried data extraction?
Architect, Registered NC, VA, SC, & GA.
dmfrazier
Here is an example of a custom program that will do (sort of) what you want:
http://www.lee-mac.com/dynamicblockcounter.html
To use this particular program, you would have to modify your DB so that the different sizes were represented by visibility states (which may or may not be feasible).
I found this among several other hits by Googling "autocad count dynamic blocks". You might find something better if you give that a try.
No I have not I will give it a try. How would I get the data into the dynamic block
That worked. It does take a lot more clicks to get the info but it does show me how many blocks and what ones have the same attribute in them
sthompson1021
Data extraction is a good tool to use but if you want just a quick count of how many 24x36 shelves you have, you can use the FIND command. Just type in 24x36 and then replace with 24x36. Make sure you have the list results box checked.find.PNG
Thanks that worked too
