Help! Page Setup and other...!
No aplicable
Hi, I need some help.
I am using AutoCAD 2018 on Windows.
I design floor plans, so I need the page layout and page setup should be same each time I create or open AutoCAD.
all I need is the page setup , layout, Layer and other stuffs should be saved so that when I create  new file I can use he old layers and page setup...
Please help!
0 Me gusta
Responder
Soluciones aceptadas (2)
521 Vistas
5 Respuestas
Respuestas (5)
imadHabash
Solución aceptada
>>I design floor plans, so I need the page layout and page setup should be same each time I create or open AutoCAD. <<
then prepare your needed CAD info ( page setup,Layers,...) in an empty dwg then save it as .dwt CAD file ( Save As command) . then you can get it always from Ctrl+N shortcut .
also you can control it from OPTIONS command (see below image )
Imad Habash
alex101000
You can also use the DesignCenter to access layouts, layers and other feature  from another DWG file.
S.Faris
Solución aceptada
I would suggest you to start a new drawing, in that file create every CAD standard that you need in common for every newly created file. For example :
Create the Layers
Load the Linetypes
Do the Pagesetup
Create the layout sheet title block
Dimension style
Text style
Then Save-as the file as .dwt in the default template folder
Next time when you create a new drawing from the Start page, select the template you created previously and all the CAD Standards you had set before will be included in the drawing.
SALMANUL FARIS
No aplicable
Thanks!
0 Me gusta
No aplicable
Thanks ! for helping.
0 Me gusta
